Queen Of The Quietlines!
Maybe a propeller will work.
Up to 534 and counting... I give up updating my profile! |
Bypassing it is not.....
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Yep, it's true....my spring switch thingy is missing! Must have broken off somewhere in my yard. I'll order the part tomorrow and hopefully be able to move my tractor out of the back yard. The neighbors were wanting to make a planter out of it! lol
Thanks, everyone, for all your help! I'll keep you posted. Thanks especially to Delta Cub, for walking me through this ordeal.
To move the tractor to the garage where you can work on it, reach under the tractor, find the connector plugged into the safety switch just in front of the brake rock shaft, pull it off the switch and plug a bent paper clip in it to bypass the switch. Start the tractor. Drive to the garage, pull the paper clip out, plug the connector back on the switch and replace the little springy thingy.
Thanks, Sawdust. This sure is a friendly and helpful bunch here on OCC. I'll be glad to get the Cub into the garage.
Well, I think I've checked all the connections. Still nothing. It did turn over when I first used the jumper wire, but stopped and never started or cranked again.
![]() Anyone know a priest who isn't busy today? |
AS A TEST.....
Run a Jumper Wire from the Battery (+) post to the small terminal on the Starter Solenoid (ORG/BLK) wire and see if it rolls over.
I love it when we all get to talk technical ![]() ![]() ![]()
Why don't ya try "moonin" it?
maybe with the full moon out, it might scare the no-start gremlins away. ![]() if that don't work do check the Bat-tree terminals, they can cause what you describe, it is easy & free. Have you tried jumper cables from another vehicle?
