Old 05-14-2018, 11:34 PM
Brownell1991 Brownell1991 is offline
Well finally got spark after cleaning the terminals on the coil. Is there anything out there on how to pull the carb off the engine and clean it? It’s not taking fuel through the carb
Old 05-15-2018, 12:46 AM
Did you try reading the engine service manual?
It is in the "Resources" section, under "Technical Library-Tractors".
Old 05-15-2018, 09:10 AM
sawdustdad's Avatar
One thought, just to confirm that it really is a fuel starvation problem, is to squirt a bit of gas into the carb while cranking the engine. It should fire for a few strokes then quit. If it does that, then you've narrowed the issue down to the carb.
Removing the carb is pretty self-evident. If this is your first rodeo, take a picture of the linkages so you can put it back together the same way.
Fuel hose, governor link, throttle and choke cables. Then...
Two slotted 1/2 inch bolts on the ears at the carb flange, loosen with an open end wrench, then use a screwdriver to remove, loosen them together, both sides a couple turns at a time. If you loosen only one, it will bind up.
You need a carb rebuild kit, carb cleaner, and a clean work area.
Old 05-15-2018, 11:44 AM
Chad126's Avatar
Chad126 Chad126 is offline
Is the fuel shut off? Unhook the fuel line feeding your carburetor. Gas should pour out.
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 05-16-2018, 07:53 PM
Ya I can get it to start for a few seconds if I shoot carb clean right in to the air intake of the carb
Old 05-17-2018, 06:08 AM
You have a Fuel Delivery problem. IF.....you have good flow to the Carburetor, then the issue is inside. Time for a tear down, clean, new Carb Kit, then proper adjustments.
Old 05-17-2018, 09:12 AM
MattC's Avatar
MattC MattC is offline
Make sure that fuel is getting to the carburetor. The lines can get plugged. If fuel is getting to the carb, I'd drop the bowl. There should be fuel in the bowl. If not, the inlet is clogged. Spray carb cleaner in the inlet until you see it coming out the other side. If there is fuel in the bowl then the main jet is clogged. Spray carb cleaner, compressed air, and/or fish a very small wire up the main jet to unclog it. I my experience, it doesn't take much to clog or unclog the main jet. At this point I'd put the bowl back on and see if she fires.
Current Fleet: 100, 126, 147, 128, 1450, 1650
Old 05-17-2018, 09:52 AM
If your carb has a steel entrance elbow, I have seen them nearly rusted closed before.
Sounds like it's carb overhaul time.
