Old 06-03-2018, 12:07 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Are the baffles on the underside in good shape?
Queen Of The Quietlines!
Old 06-03-2018, 12:11 AM
SLS327 SLS327 is offline
Its gone, rusted away.
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 06-03-2018, 12:19 AM
DeltaCub's Avatar
Not having the baffles will drastically affect the quality of cut and the dispersal of clippings.
Old 06-03-2018, 12:37 AM
Annnnndd...... there it is.
Another mystery solved. Good work gang.
Old 06-03-2018, 12:44 AM
What she said.
Way to go Beth, you are the "woman".
Old 06-03-2018, 01:03 AM
I saw a video of a guy who makes those.
The clippings removal is fine, just a small path behind the inside that stands out, otherwise it cuts good, needs new blades, but they are sharpened.
I should get a new one on since it is my only mowing machine, because it wont cut rite till its on. I will post results with two small pulleys, and see if i can find the baffle. Thanks for your help.
Steven
Old 06-03-2018, 10:13 AM
Speaking of baffles...
I'm just about to finish these up for the restoration of this unit.
(Lew, I really need that belt!!)
Cutting the square hole for the carriage bolt on the ends of the 5" radius piece is a PITA.
A 4' piece 1/8" x 1-1/4" flat will do the trick for this deck.
These are for a 38" C.I. end pin on deck I plan on hanging under the 104 I restored last year.
Old 06-03-2018, 10:22 AM
DeltaCub's Avatar
Nice work!
I am curious as to why you would mount a pin on deck to a 104? No criticism just wonderin'?
Old 06-03-2018, 10:53 AM
Squares are better done on iron worker or punch.
Nice job. I will take one of those!
There is a video somewhere and instructions for holes on these, does anyone know where thats at?
The first step was rolling the piece in a hoop. Then breaking it at the ends for the outside blades.
Steven
Old 06-03-2018, 02:20 PM
I made them in 3 pieces then welded the ends together.
The square holes were not too difficult.
mark the square and center punch 4 places inside each corner and drill 4small dia. holes.Then dress the hole with a file.
A skinny rat tail file and a 3 sided file did the trick.
A little time consuming is all.
