Good luck, let us know what you find. A little slop here and there is normal for the driveshaft and trunion. Post pics if you can, we love pictures!
Hopefully I get these pics on here for all to see
It’s at the input shaft. Leaking onto the filter and running around the filter to the bottom. Per the diagram I’m thinking #47 seal ??
Can you all see it ok? |
It’s literally dripping from the bottom of the input shaft as it spins. That’s #47 correct?? Can someone tell me a part number please.
Also I’m going to be doing Trunnion work. |
How many minutes of total run time since the filter was installed or powerwashed? And it would appear that the input seal housing has been removed at least once before. Look here for the seal: https://www.partstree.com/parts/cub-...-transmission/ |
I changed the hy Tran fluid when I got it a couple weeks ago. About 3 hrs working since then.
Yes part numbers are in reference to the diagram. I see it’s a lip seal. Looks like cub number 921-3032. Think I found it on cc specialialties web page. What all has to come apart to change it? |
Does someone have a link of pics or video showing this seal getting changed?
http://www.onlycubcadets.net/forum/s...ad.php?t=51941 |
