Old 06-05-2018, 12:13 AM
I figured it out finally...... I know why the SN shows that it is a 2004 year model, while info shows that the 2186 was only made until 2003. The correct model you should have stated is a GT2186. That was made in 2004. So, do you have a GT2186-44 or a GT2186-48?? Not that the deck size is all that important to the question at hand, but it does change the engine. You should find a Kohler Command CH20 under the hood. I do not have the spec number for it. But it won't have the 18hp, like a 2186 would have had. This is why the actual model number is important.
So, with the given info, Roland and I are correct. The 2186 was made between 2000-2003 and would have had a CH18 under the hood.
Todd is correct, that the given serial number shows the machine made in 2004.
Now we know it is a GT2186.
****This has been bugging me for days.****
Old 06-05-2018, 08:49 AM
baldy347 baldy347 is offline
Yes Sir,
You are correct, if i can get these pics on here, it clearly shows GT2186-44. I did not get a cutting deck just a front blade.
Sorry for the screw-up and many thanks for the help.
wayne
Old 06-07-2018, 05:55 PM
finally pics
Old 06-07-2018, 07:27 PM
had 2 other pics that failed to load [kept showing error code].Will try again when kids return.
Wayne
