Old 06-08-2018, 06:08 PM
cooperino's Avatar
Originally Posted by ironman View Post
I've heard it said that they cut better when they are not upside down. Can anyone verify that??
LMAO! I almost included the question are they right side up in my post about slipping belts etc.. But I am trying not to ruffle any more feathers here.. For now
Old 06-08-2018, 06:51 PM
I have no issues with my 48” deck, except a trail of cut grass between the #1 and #2 blades because my baffles are missing. They offer two different blades for the deck. Which ones do you have?
Old 06-08-2018, 10:21 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
If you really want to try non O.E.M. blades, get the length, width, thickness and center hole size and go shopping.
There are likely other brands of mowers using the same sizes.
Old 06-09-2018, 07:39 AM
IHinIN IHinIN is offline
That’s what I did. I bought hi-lift Stens blades. They didn’t have the exact dimensions though. If I remember correctly, I found a center blade the right length and width but the center hole was 5/8” and I had to open it up to 3/4”. The outer blades I found had the 3/4” center hole but were about 3/8” too long. A Bridgeport mill and a carbide endmill made them fit.
Old 06-09-2018, 08:04 AM
Dirk Diggler Dirk Diggler is offline
I was having the same problem with my 44c deck on a 782. I installed Meg-Mo blades last week and HOLY COW!!!! It’s like a different mower. It has suction, it chops the grass into small pieces and throws them 4 feet. I can drive faster and do a better job of mowing. They are kinda spendy compared to OEM blades, but they will make your mower perform
Old 06-09-2018, 09:39 AM
chzuck chzuck is offline
I have one set that is standard and one set that is hard surfaced.
Old 06-09-2018, 09:43 AM
I had looked at them a few years ago and spendy, absolutely. Didn't want to put that much money into an old mower. Glad to hear they work as advertised.
Old 06-09-2018, 09:46 AM
Do you have the 48" deck? If so, would you remember the Stens part numbers?
Old 06-10-2018, 10:00 AM
I do have the 48” deck on my 129. I’ll see if I can find the part numbers.
Old 06-10-2018, 09:37 PM
I didn’t find my receipt to figure out what blades I bought. After a little searching on the Stens site, I found blades that will work with some slight modifications. The OEM Cub blades are spec’d at 17.66” center and 16.03” outer.
Part #325-179 is 18” w/ a 3/4” hole. The length would need trimmed.
Part #330-356 is 16” w/ an 11/16” hole. The hole would need opened up to 3/4”.
