Old 06-14-2018, 09:00 PM
Originally Posted by cooperino View Post
Its not a matter of tight. I would be making a binding offer sight unseen. I am simply limiting my exposure to paying more for a machine than I should. For all I know I could pay 450$and get there just to find out there is a really bad bad problem and I would have no recourse at all.. So for that reason my offer will be low.
I agree. If the seller isnt experienced with Cub's he may be unaware that the iso mounts are bad or that the driveshaft might be toast. Just cause it runs good doesn't mean the rest of it isn't in need of repair.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-14-2018, 09:01 PM
cooperino's Avatar
I would take the 1211 over a quiet line in a fart beaat.
Well I would keep the 1211 LOL.. Would just have another cub besides the 3 I got !
Old 06-14-2018, 09:31 PM
Three is a good number, 40 is better though.
Up to 534 and counting...
Old 06-14-2018, 09:33 PM
cooperino's Avatar
If I get it will be 4 !!! LMAO I don't have room for 40 unless I build a ramp into basement
I put my offer in.. Will see what happens
Old 06-14-2018, 11:08 PM
The 1211 and 1450 are basically the same with the exception of how they look.
What?? They aren't even close to the same.
12hp/14hp
Different engine mounting systems
Different hoods and frame/ Similar seat pan
Different steering ratio
Hydraulic levers on different sides of the dash.
Way different in much more than appearance.....
Yeah, I part most of them out, them made like 200,000 of them.
Yeah.... I'm with Lew. If there is one tractor series I don't mind seeing parted out it's a QL. (Sorry Beth!) They are like the most common Cub Cadet tractor there is. You can always find a QL for sale. Plus, the '82 styled tractors are so much more comfy.
Old 06-14-2018, 11:26 PM
12hp/14hp
The engine mount in a 1211 is the same as a ql. My point was they have the same engine mount, same driveshaft setup and basically the same rearend. Other than looks and two extra horsepower there really isn't much difference.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-14-2018, 11:27 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
I am shocked and saddened... I hate to see QuietLines parted...but I must admit I have parted out a few very unloved tractors of that series. I need a drink!
Queen Of The Quietlines!
Old 06-14-2018, 11:41 PM
I always forget the 1211 and 1282 used that same POS engine mount that the QL tractors used. I do not understand why the 1050 was different, other than it is a much more rigid mount, and maybe they did that because it was a gear drive. I think the 1050 system is much better.
You know..... I wonder if you could use the same engine mount as a 1050 in a 800/1000/1200 QL and have better results.
Everyone always whines about the solid mount set up when converted.
I know Beth.... I know. It will be ok.
Old 06-15-2018, 06:52 AM
cooperino's Avatar
Well.. this helped solve some questions I had. Some guys have called the 1211 a QL and others have said no it's not. I kinda figured It was not but wondered why some called it one.
Old 06-15-2018, 07:29 AM
I don't know why Cub didn't use the 1050 style mount in all the tractors. My 1050 is the smoothest single cylinder tractor I have.
Pap's 100
Restored 108
1211 Dual Stick
1050
