Old 06-19-2018, 09:42 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Also check the rear end for loose mounting bolts and broken ears on the front end of the rear where is attached to the frame. Braces will help and fix that. I've had my 1572 since April 1987 and it has been a good tractor. I'me sure this will serve you well.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 06-19-2018, 10:00 PM
Dstein16's Avatar
Dstein16 Dstein16 is offline
Thanks everyone, I appreciate the comments. I didn’t think about additives. It didn’t even cross my mind to think about how diesel fuel has changed at the pump since the late 80’s until now.
I look forward to sharing this project with the group and plan to be more active in the forum across the board. Recently redone a 1282 and have a running 100 now on the backburner for a restoration. These cub cadets are kind of addicting!
-Derek
Cub Models: Original, 100 (x3), 1282, 1572, XT1 LT46
Old 06-21-2018, 09:30 PM
Dstein16's Avatar
Check the driveshaft out good. The diesel motor beats them up pretty good. Lots of good upgrades for that engine on the starting system. Ask before you replace any starting (including key switch) or glow plug parts.
Hopefully the injection pump isn't stuck. This bio-fuel we have now will do that. As far as similarities to a Kubota and a 7.3L..... well, they're both indirect injected, and they both burn diesel. Outside of that, nothing similar.
Speaking of key switch... what do you guys recommend? I have to order one (with keys).
-Derek
Old 06-21-2018, 10:48 PM
CubDieselFan's Avatar
The switch and the keys can be purchased separately. I bought a switch from kubota a few years back. I have seen the keys online, can probably get those from Kubota as well.
Old 06-22-2018, 12:19 AM
Yes, and that's the "key" right there... Get it from Kubota, not CCC. The part number is the same. Just take off the "KB" on the part number from CCC.
Old 06-22-2018, 08:03 AM
Here ya go.
https://www.messicks.com/part/66706-...gnition-switch
or here
https://www.amazon.com/Kubota-Tracto.../dp/B009L764YY
Tags
1572, diesel, super
