Old 06-25-2018, 07:02 PM
joeyxx2590's Avatar
joeyxx2590 joeyxx2590 is offline
No problem with the pictures. That is a good repair on the messed up holes. I bought the bearings from Eastern Bearing and they are Timken's. I also wanted to post the bearing numbers if anyone else was interested in changing theirs. I personally do not want to take the thing apart again. So I might have put a little too much grease in the CHAIN case. I am so sorry I'm not a professional cub cadet/IH mechanic and I might have misunderstood gearbox for chain case. Some people squirt oil on their chains, I have corn head grade 0 grease on mine. I can see just centering the shafts with the collars but for me it was easier to use spacers like from the factory. They butt up against the welds holding the sprockets on and done.
On a lighter note……..
I bought a couple new felt seals from Messicks to slip under the dust covers. They were a little pricey, yea I could have bought felt and cut it out but what do you do with a leftover hunk of felt? My dust covers were a little messed up in the middle so a little touch up work and all set. I evenly tightened the 3 dust cover bolts down, the felt made the shaft turn a little stiff but I oiled it and everything seems acceptable...to me anyway.
Old 06-25-2018, 10:49 PM
Great job, I filled mine up when I rebuilt it, so far so good. Yeah some grease oozes out around the shafts but not enough to worry about.
Old 06-26-2018, 11:24 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Better to have grease ooze than dry mechanism!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 06-27-2018, 12:26 PM
I think you did a good job on that one. I drilled and tapped my tiller so that I can squirt a gear oil 0 grade grease mix into it. Yes it leaks, so what. Grease fitting has been replaced with a vent.
Old 06-27-2018, 06:21 PM
joeyxx2590's Avatar
Hmm good to know about the oozing grease but ehh the thing is like 40 years old and it is not a trailer queen. I will post more pictures when I get it hooked up to the tractor. Stay tuned! And thanks for the kind words.
