Old 07-01-2018, 11:57 AM
twoton twoton is offline
.... lock out pin....
Old 07-01-2018, 01:25 PM
I use the front blade with spring assist. I think it still moves snow just fine. The blade will only do so much. It's not a truck or tractor mounted blade. It's just on a GT.
IIWII
Old 07-01-2018, 03:21 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
I made a redneck blade lift with a cheap winch. Crude, but sure is better than using my arm! (After all, when you take it all off for the summer it looks like a Cub Cadet again)
Randy
1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift
Old 07-01-2018, 08:16 PM
SLS327 SLS327 is offline
I put a 42 inch blade on my 127, the tractor has spring assist set for a snowthower, pretty tight. It worked great. When pushing snow with the blade it seemed to hold down with snow on top, buildup in front when pushing. A spring assist is an asset to any tractor. It can be adjusted to individual implements.
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 07-02-2018, 08:19 PM
They make a difference. Totally worth the $$$$$. Buy it and never look back.
Old 07-03-2018, 07:44 AM
finsruskw finsruskw is online now
If you can find a suitable spring, such as an odd one from a blade, they are fairly easy to make from scratch if you have the means to bend and weld.
Old 07-03-2018, 09:15 AM
A row unit spring on a Kinze planter is almost the same size. Already has the nut welded (made) on too.
Old 07-03-2018, 09:42 AM
There Ya go!!
Anyone have an idea as to what one of them der springs might cost??
Old 07-03-2018, 10:17 AM
I'm sure there are others out there:
https://www.ebay.com/i/262904222250?...93dce5ffff8561
Old 07-03-2018, 11:04 AM
I see the WF spring assists go for around $60-$80+ in my area.
