Old 07-02-2018, 07:10 PM
sorner's Avatar
sorner sorner is offline
86” belt routes properly cuts like a champ!
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 07-02-2018, 09:27 PM
Belt tensioners, especially spring loaded ones, ALWAYS go on the slack side of the drive belt. In other words, the side of the belt that is not under drive tension. The center pulley is the drive pulley, it is connected to the engine. It spins clockwise facing it from the top. Therefore, the section of the belt off the left side of the center pulley is being "pulled". It pulls on the pulley on the left side of the deck. Then the pulling force continues to the far side of the deck to the right hand pulley. The section of belt that goes between the right hand pulley and the center drive is not under tension. That is where the idler pulley will go. In the pic, the red line representing the belt the OP had installed, the tensioner was on the driven side, or tension side of the belt. Therefore, the torque would simply collapse the spring, and the section of belt between the right pulley and center pulley would go slack, and lose friction as the belt entered the groove on the RH pulley.
Belt routing 101: Spring loaded tensioner ALWAYS goes on the slack section between the last driven pulley and the drive pulley.
Old 07-03-2018, 06:02 AM
sorner's Avatar
Thanks. From now on I know when I part is called for and what I have taken off doesn’t match up, the PO did something and I need to dig into it and figure out why.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-03-2018, 06:33 AM
The "belt route" can be found here at this Link..... Operator's Manual
On the 44/50 decks, it is on Page #10.
