Old 07-04-2018, 10:08 PM
Those are rare as hens balls.
Looks like a 50.00 part to me.
Old 07-04-2018, 10:21 PM
DieselDoctor's Avatar
Thumbs up
Lucky boy! Saw that and passed on it cause I had another lined up. Glad you got it.
Old 07-04-2018, 11:15 PM
Dirty Steve's Avatar
No chit!!! A cyclops Unicorn for sure!!!
Old 07-04-2018, 11:33 PM
Terry C's Avatar
Terry C Terry C is offline
I’ve never seen one. Cool
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-05-2018, 12:26 AM
You SUCK!!!
Heck of a deal right there, good haul "Master of Steve"...
Old 07-05-2018, 10:26 PM
I had a few extra minutes today so I pulled the covers off the deck then removed it from the tractor. PO said they replaced the PTO 3 years ago. Said it was cutting out in tall grass. They got fed up and sold it.....to me.
The deck belt was twisted inside out and above the pulley grove on left side.
No rust holes in deck. Unfortunately both outside bearing cup holes are twisted causing the deck to be out of level. The blade tips are off nearly a half an inch in the center.
The theory on the PTO was troubling to follow. I finally discovered a possible problem.
Look at the double pulley.
The PO told me the pulley was new along with center spindle last year.
The pulley is upside down. The smaller diameter should be on the bottom!!!
Both belts seemed nearly new but both them have issues and just may be junk.
Not sure if the PO did their own wrenching or if someone else screwed up the pulley placement.
Leads me suspect the PTO clutch is probably fine. The engine to deck belt would not get tight enough on that smaller pulley. They said it would "cut out in tall grass after a while."
However, the deck is not as nice as I had hope. There are stress cracks in the usual spots. Gonna have to trade labor with my brother for some welding help.
Oh, and as always the dang idler pulley bearing is shot. Wish that was replaceable.
Old 07-05-2018, 11:30 PM
john hall's Avatar
Old OCC trick, drill out the rivets in the pulley, put in a new bearing, and bolt back together with small bolts or rivet like original. Never done it yet, just learned of it here a looong time ago.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 07-06-2018, 12:04 AM
I was going to say the say thing John. Steve that bearing is replaceable. If you have troubles call or text me. I may even have the bearing.
Old 07-06-2018, 03:05 AM
I have seen it done here before. After a quick search I found a post from Mr. Sam Mac.
http://www.onlycubcadets.net/forum/s...pulley+bearing
Thanks.Sam!
There may be others too.
Old 07-06-2018, 07:35 AM
Heck of a good deal there Steve and it looks nice too.
Yes, the bearings are easy to do. As Sam said, they are just a 6203 double sealed bearing with a spacer.
I picked up a sleeve of these bearings and so far they have worked great.
https://www.ebay.com/itm/Qty-10-6203...sAAOSwQoFWQNr4
