Old 07-19-2018, 11:04 PM
john hall's Avatar
Originally Posted by sawdustdad View Post
It's worth every penny. I believe it is what launched the entire compact tractor industry in the US. These things are built tough. I used one as a log skidder for many years and can;t tell you the abuse I put it through. No cheap stamped steel here, everything is thick, welded plate and cast iron. Heavy duty Hydrostatic trans with oil cooler, horzontal shaft engine with direct drive PTO. PTO clutch. driveshaft on front for accesory takeoff, class 0 3 pt. hitch. "
Whoever wrote this has a completely different definition of compact tractor than I do. To me, the Yanmar built Deere's of the 80's are what got the compact industry moving. Those are a real tractor, just lacking load and depth on the 3pt and having to deal with a 2 stage clutch. I used to run the heck out of a 670 Deere maintaining grounds for a sub division, including riding trails and power lines.
That Simplicity is just a lawn mower, a nice heavy one, but still a lawn mower---just like my Cadets.
The line about being a "log skidder", well guy must have lived on 3/4 acre in suburbia his whole life.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 07-19-2018, 11:49 PM
^^^^ What John said. I've skidded logs, and he ain't skidding "logs" with that machine. I'm a thinking his definition of "logs", ain't the same as mine...
Old 07-20-2018, 10:03 AM
Chad126's Avatar
Chad126 Chad126 is offline
For $2,100 I would expect something without a plywood dash that looks like my two year old cut it out with his plastic hand saw.
That aside, it still isn't a cub.
I don't have a vast background of mechanic work. I'm not an auto tech or tractor tech. But I've rebuilt several machines, and the cubs are by far the most well built that I have seen for a GT. The engineering behind these machines is simple but much stronger than their competitors. I know that is a broad statement, but it is true.
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 07-20-2018, 02:00 PM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
Not sure how a '97 tractor could have started the compact tractor craze but Simplicity tractors in general are well built, I dont see alot of Simplicity branded ones around here but I find alot of Allis Chalmers which is the same thing. I have a 718 in the shop now and Im picking up a 712 this weekend, and my fav mower is a Deutz Allis which is also a Simplicity machine.
$2100 is a bit much for that 75th edition imo but around here it would sell for more than most any comparable tractor, except maybe a Case or JD, a comparable Cub wouldnt bring much more than $1000-$1200cad
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 07-20-2018, 03:13 PM
I'll stick with my Kubota BX with the FEL.
Old 07-20-2018, 08:32 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Check out this 1985 Simplicity, looks as if it was in a time capsule.
https://philadelphia.craigslist.org/...643098181.html
Old 07-20-2018, 09:14 PM
Billy-O's Avatar
Billy-O Billy-O is offline
That 7117 looks beautiful!
Plow blade
#2 Cart
QA36 snowthower
Old 07-20-2018, 09:20 PM
My 7116 was better, it had hydraulic lift, 3 point hitch too, and was purdy...
As for that 75th one, there was a guy selling that same machine for 2000.00 in the county seat.
That is the same one, as I remember the serial number, and the wooden dash now i thought about it.
Old 07-20-2018, 09:47 PM
Billy-O's Avatar
I was just looking at the Simplicity Sovereign earlier mentioned on eBay. Of all the pictures shown, it seems one picture show the crankshaft.....isn't the tractor missing a PTO? Just curious........
Plow blade
#2 Cart
QA36 snowthower
Old 07-20-2018, 10:15 PM
Double07...that tractor should be banned!.....it says "semi automatic" on the hood so it must be an assault lawn mower.
Here are 2 of those machines that were at the Evansville show this year. I think they should be called a Pimplicity.
One of those was for sale up in South Carolina a year or two ago for $3500, I'm thinking it is still available.
