Old 10-16-2018, 12:49 AM
Albertj Albertj is offline
Originally Posted by sawdustdad View Post
It's possible that the fiber button has worn in against the PTO's thrust button, and all you need to do is take up some slack with the turnbuckle in the actuator linkage to apply a bit more pressure to the PTO. The fiber button does wear out and some adjustment of the linkage is commonly required, until you finally have to replace the fiber button.
Thanks - I am both going to look at this and to pull the clutch. Found another thread on this site that comes into details of remounting the PTO clutch after a clutch rebuild. Between these helpful comments and reviewing the other threads I think I can fix this.
I will be traveling this weekend, and I'll get this fixed ASAP, definitely before i hang the snow thrower attachment on for the winter. I think we have 1-3 mows left in this fall season.
