Old 08-15-2018, 05:36 AM
Wasn't this one the first zero turn in '63?
“In 1949, Warrensburg, MO resident Max Swisher invented the very first commercially available zero-turn mower and called it the "Ride King". It was a three-wheeled machine - one drive wheel in front and two in the rear. The patented system utilized the front wheel as the drive wheel that also was able to turn an amazing 360 degrees. The wheel was driven by the motor in the same direction 100% of the time. In order to reverse and/or utilize the zero turn capabilities, you simply turn the steering wheel 180 degrees and the mower would move in reverse”
Old 08-15-2018, 11:29 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
The patented system utilized the front wheel as the drive wheel that also was able to turn an amazing 360 degrees. The wheel was driven by the motor in the same direction 100% of the time. In order to reverse and/or utilize the zero turn capabilities, you simply turn the steering wheel 180 degrees and the mower would move in reverseā€
That drive would be great thru the hull of a little flat bottom boat!
Old 08-15-2018, 11:47 AM
cooperino's Avatar
Amphibious tractor??
Old 08-15-2018, 12:33 PM
I was trying to use that drive and mount it on the frt.of a dump cart , once
My neighbor had 3 swisher mowers ,he and his wife used them in tandem , they work good on hilly slopes ,your not going to turn one over , the ones he had anyway. ....some people want to mow as slow as they can ...it will happen to you , if you live long enough
Old 08-15-2018, 04:30 PM
cooperino's Avatar
So, here is the one near me. I inquired about it. I figure what the hell. Lol
Old 08-15-2018, 06:44 PM
Terry C's Avatar
Terry C Terry C is offline
You all need help.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-15-2018, 07:40 PM
Buy it it is red so you can have a nudder red one..
Up to 534 and counting...
Old 08-15-2018, 08:06 PM
cooperino's Avatar
Crap.. its sold.
Old 08-15-2018, 10:30 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Crap.. its sold.
Don't worry, you'll make a clown someday.....
Plow blade
#2 Cart
QA36 snowthower
Old 08-15-2018, 10:41 PM
Billy-O's Avatar
Crap.. its sold.
Plow blade
#2 Cart
QA36 snowthower
