Old 07-14-2010, 01:08 PM
Originally Posted by kennygibson View Post
I just found a picture of a "Curtis Cab"... the windshield looks to be angled in so the hood can open?? That's what it looks like... has anyone ever had or seen one in person? Seems pretty crazy to lock down the hood with a cab frame. What if the battery needs attention?
I have the top and front from one of those, but I haven't tried to put it on anything yet.
Old 07-15-2010, 09:15 AM
kennygibson kennygibson is offline
Matt, if you ever get the chance to put that on something, I'd love to know/see how it works out.
I also found a couple pics of a Sims cab (on the 482-982 series) that is a very cool design... the windshield flips up and out of the way of the hood. I'd like to find out if they ever made that design for the NF or WF cubs...
Ken
Old 07-17-2010, 08:35 PM
fer100's Avatar
fer100 fer100 is offline
I picked up a curtis cab(from a JD) this spring.It does sit on the hood on a 3 inch rubber strip and has turnbuckles that hold the front windshield down while the rear bracket bolts to the fender. But you undo the turn buckles and lift up (rear brackets are hindged) the whole thing. To open the hood to gas up. Haven't tried to mounted it yet. Will let all know when I get it set up. I really don't want to drill into my fenders. Trying to find a different mounting set up.
,1 Ariens 934 Hydro with cyclone rake
Old 07-17-2010, 08:51 PM
kennygibson-
I'll be mounting it to an 82 series, so I'll have to figure out how to hinge it so that it's out of the way of the VERY LARGE hood on those tractors. I'm not sure when it's going to happen though...I have too many projects.
Old 07-17-2010, 09:54 PM
fer100's Avatar
kennygibson-
With the rear brackets hinged it would be out of the way with room to spare
Old 07-17-2010, 10:13 PM
Yeah, I'd just rather not hinge the whole thing. I have to get it out sometime and play with it a bit. I bought it and then buried it in the barn.
I'd like to make either the front flip up or to the side. I'm not sure that I could easily make it flip to the side, due to the shape of the front panel.
Old 07-18-2010, 01:15 AM
fer100's Avatar
I understand, what I was thinking of doing is cutting the front 2 inches below window putting hinge in then runninng some steel down the front side to the front foot rest and welding or bolting it there. Flip up hinge part and open hood. What I notice with the hinge on the back support is that it was bent a little bit. Right now mine is burried in the back of the garage also.
