Old 10-01-2018, 08:17 AM
I have a 1282 you can come pick up for $100 wtih no engine but it's already got the mounting for a single cylinder.
So I'm guessing you're not interested?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-01-2018, 08:49 AM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Sorry, I hadn't seen your reply about it.
I might buy it. I've been asking around for a while trying to find a tractor, it'll be perfect, easy swap. If I do buy it it'll get a hydraulic lift and a few other misc. things. Do you have any pics of it?
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 10-01-2018, 10:39 AM
Mudrig150's Avatar
My plan for a CV driveshaft swap into the future roller: Take a driveshaft from a 318 onan and buy two engine side yokes, make the bolt holes fit and use it to eliminate the flex coupling by bolting it straight up to the stock driveshaft couplings. This, I hope, will also eliminate the problem of the flex couplings getting warped, causing vibrations, like on my 1250. I might have to modify the yoke ends to bolt up, and shorten the driveshaft, but it'll be so nice.
Hopefully it'll go as planned.
Old 10-01-2018, 11:49 AM
Gompers Gompers is offline
Seems like a lot of work for something that really isn’t a problem with good components. But you do you.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 10-01-2018, 12:07 PM
Mudrig150's Avatar
I'm mainly doing it to allow for more engine movement and to allow for more flexibility if I want to swap in something bigger. Also it'll be way easier pulling the engine of transmission, and I won't have to worry about roll pins breaking or the whole driveshaft destroying the hydro lift..
Old 10-01-2018, 12:14 PM
Leadslingingdaddy's Avatar
Your NOT doing it yet.... you're maybe, might, hopefully planning on doing it... In my day that's called daydreaming
Old 10-01-2018, 12:17 PM
Mudrig150's Avatar
It's in the works. How am I supposed to work on something I don't even have yet?
Edit: Looking back, you guys mentioned that the Pto is different. If it's a 1282 would the whole PTO or just the pulley be different? If it's just the pulley, could you swap them? I don't see why not.
Old 10-01-2018, 12:28 PM
Here's a pic of the 1282. I have the tunnel cover for it and the plate the seat bolts to, I don't have side panels.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-01-2018, 12:29 PM
Mudrig150's Avatar
That'll be fine, I can't use them anyway with the exhaust I have for the 14 hp.
Does it have a grille or headlight panel?
Old 10-01-2018, 01:01 PM
I have a grille but no headlight panel.
Pap's 100
Restored 108
1211 Dual Stick
1050
