Old 10-01-2018, 01:14 AM
RumbleFish RumbleFish is offline
I drug home a 1641 that had a large plastic mug screwed right to the side of the hood. It looked terrible.
Jeff
62 O, 1641, 1864, 1862, 1535, LT1045
#4 cart
Old 10-01-2018, 12:07 PM
1811woody's Avatar
I'm thinking of a cup holder that would be mounted by silicon to the shaft cover I've spilled more cold beverages or hot coffee than I can count. I think olds45512 has the right Idea using the pvc painted cub yellow I may have to steal that Idea. I thought I would have a slot in the side for the handle.
Old 10-01-2018, 12:12 PM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Don't be like the PO of my 1250, he bolted a van cupholder to the fender to hold a drink. Now there are 5 bolt holes with corrosion around them on my fenders. The best part was that he used those square bolts that prevent the bolt from spinning.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 10-03-2018, 10:04 PM
Dirty Steve's Avatar
My 2284 came with this plastic crap screwed to the hood.
Old 10-04-2018, 08:11 AM
cooperino's Avatar
I guess its mounted that way to keep a beverage hot Any cup holder I have had on a tractor vibrated so badly that it would make a beer go flat in a couple minutes.
Old 10-05-2018, 01:14 AM
Drink faster
I never drink anything carbonated when mowing for this reason. Even holding your drink while you mow can get hectic with dash control hydro.
Jeff
#4 cart
Old 10-05-2018, 06:46 AM
cooperino's Avatar
Originally Posted by RumbleFish View Post
Drink faster
Think I might try something like this to eliminate vibration. Plus its self righting at least in one direction. I like the small concealable mount and that I can take take the holder off easily leaving the mount
Old 10-05-2018, 07:01 AM
I have used this on 4 tractors, and 2 ATV's,,, perfect results,, and it is insulated.
It will stick to diamond tread and not move,,
I purchased it from Amazon.
Old 10-05-2018, 11:48 AM
cooperino's Avatar
I really like that one! going to Amazon now!
Old 10-05-2018, 11:57 AM
Is it big enough to fit a 20oz pop bottle?
Pap's 100
Restored 108
1211 Dual Stick
1050
