Old 11-02-2018, 11:36 PM
The Idler Beth mentioned in post #7 will mimic the condition you describe.
Deck seems to slow down and engine don't compensate for a phantom load.
Most of those are neglected and are dryer than a popcorn fart.
Old 11-06-2018, 09:58 AM
samckitt samckitt is offline
Originally Posted by cooperino View Post
How recent? Have you noticed and smoke? Any loss of oil? Is it just the deck that seems weak?
Sorry I havent checked here in a couple days. It seems like it has been slowly loosing power. It doesn't smoke, burns a little oil, but not excessive. It's not just the mower deck that affects it. Just running it at full throttle & pushing up on the lever to make it move makes it bog down (governor doesnt seem to kick in to give more power).
________________________
Scot
Old 11-06-2018, 09:59 AM
I don't want to sound silly, but have you replaced the air cleaner recently?
I will try that, thanks.
Scot
Old 11-06-2018, 10:01 AM
Deck is clean of grass, I will check pulleys & idler. Thanks
Scot
Old 11-06-2018, 11:24 AM
cooperino's Avatar
If it does it just by moving you have other issues. It could be as simple as fuel problem. Dirty filter or clogged line. I would go through the fuel system completely first.
Old 11-06-2018, 08:33 PM
CubDieselFan's Avatar
When was the last time the air cleaner was serviced?
Old 11-06-2018, 08:40 PM
Sometimes it's a simple thing that reduces power. On my 125, it was as simple as tightening a clamp on the carb. ( sorry but your carb has a different assembly. They upgraded this older version )
https://www.onlycubcadets.net/forum/...ad.php?t=53358
Old 11-07-2018, 11:56 AM
Hmmm, probably last summer. My couple acres has alot of bare spots this year & therefore kicks up alot of dust when mowing. So this very well could be the culprit. Picking up new one today.
Scot
Old 11-08-2018, 02:50 PM
sorner's Avatar
sorner sorner is offline
If it's dry, grease it up so it's wetter than a Taco Bell fart...
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 11-10-2018, 05:26 PM
hogfly hogfly is offline
Default 1863
dont use my 1863 much do start regularly use it today to pull some trees went to put it away and engine started surging and cracking when on demand if you open choke a little it helps some but still does it any suggestions on what to look for once it starts doing it it even does it when idling thanks guys its dark now but will check in morning
