It looks like the 100 has regular battery cables on it. Battery tray is 10.5"w x 6.5" deep x looks like 9.5" tall.
here is a pic.
Well gonna chime here, I'm in the process of a restore of a 100 at present. I'm gonna use a battery that fits the box if it is a car battery or a lawn battery. Makes no difference to me. If it works?? what can I say?
[B]Larry[/B] |
Stock battery box with U1 battery.
Looks Good Bill, But my 100 has the car battery connections on it, Now maybe the PO changed them. Anyway I'm ordering a new wiring for it, so if it comes with that type of terminal, that is what I will use. Thanks for the pic.
[B]Larry[/B] |
Here's the specs on a NAPA 8223 battery
Battery BCI #: U1 Battery Cold Cranking Amps @ 0 Degrees F: 230 Battery Cranking Amps @ 32 Degrees F: 285 Battery Electrolyte Composition: Acid Battery Posts Type: Top Post Battery Voltage: 12 Battery Weight: 15.5 lbs CA @ 32 Degrees Fahrenheit: 285 CCA @ 0 Degrees Fahrenheit: 230 Height: 7 1/4 in. Length: 7 3/4 in. Polarity: Left Positive Here's a NAPA 7581R for a 1992 Mazda Miata Battery BCI #: 46A24L Battery Cold Cranking Amps @ 0 Degrees F: 320 Battery Cranking Amps @ 32 Degrees F: 400 Battery Electrolyte Composition: Glass Mat Battery Posts Type: Top Post Battery Reserve Capacity (Minutes): 45 Battery Weight: 25 lbs Height: 7 1/4 in. Length: 7 3/4 in.
Current: 102 122 SZ60 Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265 |
There are manufacturers that make higher CCA L&G batteries.
FOr an example sears makes one thats 340 CCA Actually. Im positive sears does not make this as there are only a few batteries manufacturers in the US and sears is not one of them. Anyway, yiu can get larger capacity L&G batteries is the point. DieHard Sealed 340 amps Lawn and Garden BatteryItem no. 8367336 | LG-3 Read 1 Review|Write Review $64.99
NAPA also carries a higher U1 battery.
8227 Battery BCI # U1 Battery Cold Cranking Amps @ 0 Degrees F 350 Battery Cranking Amps @ 32 Degrees F 430 Battery Electrolyte Composition Acid Battery Posts Type Top Post Battery Voltage 12 Battery Warranty in Months 12 Battery Weight 19 lbs CA @ 32 Degrees Fahrenheit 430 CCA @ 0 Degrees Fahrenheit 350 Contents (1) Battery Assembly Freight Class 65 Hazardous Material Yes Height 7 1/4 in. Length 7 3/4 in. |
What is the serial number of your 100? My 100 serial is 84XXX. It has a big battery with round post on it.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Found a picture of my 100 with a big battery:
