Old 11-21-2018, 08:26 PM
This is the wiring diagram for the 1541. You should be able to turn the key to run and jumper the start solenoid to get it to crank.I use one of those push button remote starters that you can pick up at an auto parts store. Lock the brake down first. If it's been sitting for a year and a half you probably also have fuel issues. You may need to squirt some fresh fuel into the carb throat. I use an old gear oil bottle with a pin hole in the end so you don't over do it.
