Not knocking you guys with the dually's, but not for me. Guy I talk to on Facebook run Carlisle field trax and really likes them. May consider that. What about for the front? I do have some trouble steering with the blower down.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
Chain up your turfs with 2 link chains.
Load the tires and attach wheel weights, the more the better. I have no idea what you mean as to "tearing up the driveway" If you are the kind of person that don't like scratch marks on an asphalt/cement driveway, I suggest you use a hand shovel. If it is gravel or dirt, raise the blade to just skim the surface. Ag tires work best in a garden, if chained up, very little contact is actually made to the surface below.
[QUOTE=ol'George;472667]Chain up your turfs with 2 link chains.
Load the tires and attach wheel weights, the more the better. I have no idea what you mean as to "tearing up the driveway" If you are the kind of person that don't like scratch marks on an asphalt/cement driveway, I suggest you use a hand shovel. If it is gravel or dirt, raise the blade to just skim the surface. Ag tires work best in a garden, if chained up, very little contact is actually made to the surface below. [Like gouging the asphalt pretty deep. |
Narrow rims/tires on the front works great for me. They sink into snow more than wide ones.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
[QUOTE=hemimike;472672]
I do my neighbors large asphalt driveway and pay attention to my fwd/reverse action and speed, so as to minimize scratching. I have never, ever had a problem with gouging. I can only think it would caused by soft asphalt or sitting and spinning??
Driveway isn't in the greatest condition but not sure how much more weight I can add. Already have 4 suitcase weights and Tire weights.
How do rib tires work in snow/mud? |
I would recommend Tru-powers or 23* Firestones if you get Ag tires. The 23-10.5 Tru-powers measure a true 23" tall. The other tires like Deestones run smaller height wise. I've seen 24-12x12 turfs on a 3000 series and the tires rubbed the gas tank. A wheel spacer or recentered rim is needed. The guy with that tractor took a belt sander to the tread edge to get clearance. ![]() Just to add some random info. Some 3000 series tractors came with 23-9.5x12's on 12x7 wheels with 2 different back spacing versions. They only measure 22" tall at most.
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder 3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller 1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers |
16x6.50-8 Vredestein V61 5-Rib tires work way better then turfs in mud and snow
I want to try a hdpe cutting edge on my blower at some point this year. It should scrape the driveway clean without scratching it.
