Old 12-10-2018, 11:08 PM
There is so much green on the hood,, maybe you need to finish it with some JD paint??
Looks like a good project,,,
Old 12-17-2018, 01:09 AM
Bulldog106 Bulldog106 is offline
I don't mind the green as long as no one mistakes it for a John Deere!
This 127 is turning into a parts tractor on me. I stole some parts today to go on my 106. Good news the 106 started for the first time in 15 years!
I got to look over the 127 a little closer today and a lot of little things are missing or in rough shape. I noticed they bought the wrong coil from NAPA. A very nice 12v external resistor type and the electrical wiring has been redone, poorly. This isn't going to be a quick fix tractor.
Is there a way to test a hydro without an engine? I would hate to sink money into an engine rebuild only to find out the hydro doesn't work.
Old 12-17-2018, 08:44 AM
jbrewer's Avatar
jbrewer jbrewer is offline
one good wash and you'll find a keeper there.
Great deal!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-17-2018, 08:47 AM
Billy-O's Avatar
Billy-O Billy-O is offline
The hydros on the IH Cub Cadets are "considered" bullet-proof. It's very rare to find something fatal. There are numerous small issues that renders the hydro inoperable but can easily be repaired. Some of those issues are broken/missing driveshaft pins, bad/stuck relief valves, dirty/old filter and oil (change), some leaks (the famous cork gasket) and some other wear and tear issues outside the tranny. You might spare some change but this isn't excatly a money pit.
Plow blade
#2 Cart
QA36 snowthower
Old 12-17-2018, 10:40 AM
Gompers Gompers is offline
I'd wager a fair sum of money that the hydro works fine. Those things just don't go bad. You can chuck up the driveshaft in a drill and spin it if you're worried though.
The wiring in my 127 is pretty bad as well. Worse than my 125 for sure. You can build a new harness fairly cheap, or I'm pretty sure they are available for not too much.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 12-17-2018, 01:02 PM
That’s good to hear about the hydro being bullet proof. I’ll have to keep an eye out for a deal on the rest of the tiller pieces. Not sure how common they are. I could make good use of that in the garden. A snowthrower would look good on the front too. I’ve seen a few of them for $100. Is a qa42 too big for the 12hp? Would it work better with a 36?
I could build a harness for my 106 while I am at it for very little extra. The battery cables and starter generator cables are rough on that one too.
Is it odd that I get excited about a 106 and a 127 sitting next to each other in the garage?
Old 12-17-2018, 01:09 PM
You basically just need the tiller and possibly a mule drive depending on what is on that one. Shouldn't be too hard to come by. Sans gear box they go for maybe $150-$200 around these parts and a few come up a year. Belts are pretty expensive for them though.
You'll want a QA42A, but a QA42 will fit as well. Definitely not too big for the 12HP, though more HP is always better with a blower. The 12 HP was the "big" cub until the 147 came out, and it'll blow just fine with that 42" blower.
Old 12-17-2018, 01:17 PM
Billy-O's Avatar
I heard nothing but good reviews for this wiring harness from this guy: https://www.onlycubcadets.net/forum/...ad.php?t=34457
For the price, it's a better deal than making your own!
Plow blade
#2 Cart
QA36 snowthower
Old 12-17-2018, 02:46 PM
Bamafan Bamafan is offline
Inactive Member
As Billy-O said, you cant beat the price and quality of the harness he makes, I have bought 3 from him.
[B]Larry[/B]
Old 12-17-2018, 09:01 PM
Add another completely satisfied customer. Electrical is far from my strong point and everything is clearly labeled and easy to install. Great price too.
HIGHLY recommended
