You will need a 1" pipe tap with the about the first 3'8th inch of the leading edge cut off so it doesn't bottom out and some good tapping fluid. You will need to be extremely cautious while doing this as the area you will be chasing will be work hardened from all the heat cycles.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
I thought he was indicating there were no threads lrft to chase...
Still no picture tho
Blah, blah, blah...
Well it'll work, but I don't know how well it will.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210 Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60 |
Well Cooperino the existing threads could possibly be full of carbon giving the appearance of compromised threads. Unless you chase out the existing threads you have no idea what you are dealing with.
I know that the threads are messed up because why else would the wrong exhaust fit but the original elbow doesn't?
Like, they're there but they're sized up.
Appearence? There's literally no chunks of carbon on the threads. They're tapped for a bigger size pipe, that's all.
How about an appearance of photographic evidence of what you're describing?
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
Very good recommendation on the flange thingy. Halb, halb, halb...
