Old 12-29-2018, 03:38 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Default Nutserts
Hey Roland,
I have used nutserts many times and they work just fine.
They may require a rivet gun type of install, but they are not too expensive.
I have done the larger ones using a bolt and a screw for compression and in some cases used a washer on the back side for taking up any gap.
https://www.amazon.com/s/ref=nb_sb_n...32+nutsert+kit
I have used standard DE grease such as this for many years with no issues:
https://www.walmart.com/ip/CRC-Diele...gaAq_nEALw_wcB
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 12-29-2018, 06:09 PM
sorner's Avatar
sorner sorner is offline
I’m sorry.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 12-30-2018, 12:34 AM
sawdustdad's Avatar
I use Penetrox A on electrical connections in the panel. Mostly for aluminum to avoid oxidation, but I think it would be fine for the breakers. I believe the breakers come with some sort of grease on them already, at least most I've seen have it.
