Old 01-08-2019, 11:52 PM
ColoradoCadet's Avatar
ColoradoCadet ColoradoCadet is offline
I am working on my hydro pump. Got the gunk off and now I am focused on getting it nice and clean. I want to get the relief valves rebuilt since I understand that is a very common problem. They are in there really tight. Any suggestions on how to get them out? I don't want to damage the pump, so I'm not sure what I can get away with doing.
Has anyone taken advantage of this service on ebay?
https://www.ebay.com/itm/REBUILD-SER...Lil:rk:13:pf:0
Thanks,
Wayne
Old 01-09-2019, 09:41 AM
Bamafan Bamafan is offline
Inactive Member
To remove the relief valves use a socket or a box end wrench, if they are really tight use a hammer and TAP the end of the wrench they should break loose.
That E-bay seller is the service I used to rebuild 4 of my valves, I was well pleased with the service.
[B]Larry[/B]
Old 01-09-2019, 10:18 AM
Vrobert's Avatar
Vrobert Vrobert is offline
I would get it running again and check if they are leaking. No need to spend the money if they are ok.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 01-12-2019, 10:00 PM
I got the engine started today, first time in 4 1/2 years. - Link to video removed since it didn't work. Sorry.
Wayne
Old 01-12-2019, 11:39 PM
Originally Posted by ColoradoCadet View Post
I got the engine started today, first time in 4 1/2 years. - https://www.facebook.com/waynes.mail...4332391591283/
Yer link don't work for us non believers in spaced out bookie thingy
Old 01-13-2019, 12:01 PM
Hmmm, I don't know why but maybe you have to have an account with them? I will remove it to eliminate the confusion. Thanks. Regardless, I was pretty happy to get the engine running.
I am finding plenty of pieces that need to be replaced, I am assuming these are pretty normal wear items.
Wayne
Old 01-14-2019, 07:44 PM
I dug into the steering column today. I don't know what they normally look like, but this was really stiff. All of the ball bearings were there, but they come out of the race pretty easy. The cam follower has a couple of spots that are a bit flat. This looks like a great buy to clean things up a bit: https://www.ebay.com/itm/Cub-Cadet-1...-/322240084280. Any recommendations on this segment of the rebuild?
Wayne
Old 01-14-2019, 11:56 PM
sawdustdad's Avatar
Looks like a good deal. Probably need to get a new seal for the box, clean it all up and reassemble with lots of grease.
Old 01-15-2019, 12:18 AM
- Glad you said that, the seal was totally shot and forgot to add it to my "purchase" list.
Wayne
Old 01-22-2019, 05:05 PM
I am doing spray can primer (for convenience), and will use Van Sickle enamel tractor paint for top coat. Hope that will work out.
Wayne
