Old 01-04-2019, 06:26 PM
Putting the filter in the return line should not change anything as far as performance, it is just a filter.
Hopefully you have a bit of air in the system and it will work out.
Do remember you are in colder temps and
it affects the oil's ability to flow.
If possible, have it inside where it is warmer.
Do not use tractor fluid "303" in anything in lower temps.
Many complain using it in winter, some larger tractors/construction equip refuse to operate with it, as it is just too thick.
Old 01-05-2019, 08:10 AM
I am using Hy-Tran in my DanCo 2149 mounted on a Restored 149.
After the initial purge when 1st assembled after restoration, No issues at all with performance and/or foaming.
It will be slow when started in cold temps no matter what oil you use.
The filter on a 2149 is mounted to the valve body.
Old 01-05-2019, 08:58 AM
twoton twoton is offline
...and is there a vent on your fluid reservoir?
Old 01-05-2019, 09:21 AM
I'm running a filter on the suction of my Kwik Way loader with the cheap TSC oil with no issues. As others have asked, what is your pump and suction line size?
Old 01-05-2019, 12:15 PM
The vent is a tiny hole in the filler plug located on top of the RH upright where the valve body is located
Old 01-05-2019, 12:41 PM
Old 01-08-2019, 08:19 AM
Palskidoo Palskidoo is offline
Attachment 97747
Suction line size is 1/2" and the pump suction side is JIC-8. I did find an issue where I had trapped some air in the system so I added a vent to let the reservoir breathe.
I am waiting on some hydraulic fittings before I can put the oil back in and see how she runs.
I wanted to get this done and running before snow, but, as any of you in the northeast know right now... rain is about all we can get
Old 01-08-2019, 04:02 PM
Merk Merk is offline
Originally Posted by Palskidoo View Post
Suction line size is 1/2" and the pump suction side is JIC-8:
I have set of PF Engineering loader plans. PF Engineering is calling out 3/4 inch (-12) fittings on the suction side. They also recommend a pump with an 4 to 8 GPM.
This might be an area to look at. If my memory is working right a suction filter and high pressure filter are different.
Project Uncle Dick
Cub Cadet 70
Old 01-08-2019, 09:38 PM
Here is the pump I used.
https://www.northerntool.com/shop/to...9706_200329706
My suction is 3/4"
What filter are you using?
Old 01-08-2019, 10:02 PM
This the pump I planned to use on my Kwick-Way loader:
https://www.northerntool.com/shop/to...isSearch=10567
Project Uncle Dick
Cub Cadet 70
Tags
149, fel, front end loader, hydrualic oil
