Took a better pic of the hydraulic set up as requested. I also found this manual lift bracket. Think I can modify it to work with the hydraulic lift?
Also the last two pics are of the clutch and the hour meter. The clutch is supposed to have a cover, but is there a special one due to the hydraulic lif equipment being in the way? Is the hour meter original or an aftermarket add on? Previous owner said it quit working 15 years ago.
Proud Owner of These Fine Cubs 1961 Cub Cadet Original - 1966 Cub Cadet 102 - 1967 Cub Cadet 104 w/ hydraulic lift |
Yup, That will work, just cut it off where the manual says to, find a clutch cover an do the modification on it per the detail in the manual and you are all set.
Mosey on over to the manual section and download the manual for the NF hydraulic lift. |
Thanks for that tip on the manual!
