Old 02-02-2019, 08:28 PM
Originally Posted by 35boulder View Post
So I'm still trying to get this (new to me and this 100) sleeve hitch installed. I have installed the rear pivot to the frame under the seat. I have tried to attach the lift plate to the lift bar and pass it along the inside of the frame to where it attaches to the ratcheting lift bar but the lift plate will not pass the frame bolts.
So I next separated the lift bar from the lift plate and installed the lift plate by itself to the ratcheting lift bar but there is not enough room to then get the lift bar over the pivot on the lift plate. I have looked at the chassis manual but there is no mention/directions on installing one of these. So i'm asking again for any help or directions on how to complete this. Thanks again.
On my former 122, I had to remove the curved, slotted plate to get the lift bar and plate ( assembled ) into position.
I will admit the "universal adjective" was used quite a bit.
Jeff
Old 02-02-2019, 09:24 PM
Send the lift bar through first, then install the lift plate.
Old 02-02-2019, 09:37 PM
athomas's Avatar
athomas athomas is offline
Did you see these instructions ? http://ccmanuals.info/pdf/NF%203%20PT.pdf
Old 02-03-2019, 11:49 AM
35boulder's Avatar
35boulder 35boulder is offline
Thanks for all the help. I appreciate the link to the manual. I searched but could not find one. I'll keep working at it! Thanks again for the replies.
Old 02-03-2019, 05:45 PM
35boulder's Avatar
Just wanted to say thanks to all that replied with suggestions on the sleeve hitch install. After much body twisting and all that goes with that I was able to get the lift bar and plate installed on the 100. For those that have not attempted this you DO have to unbolt the ratchet on the lift lever. With that unbolted and the spacer removed the rest falls into place. Thanks for all the patience shown by those that replied and for the link to the install manual. On to the next task.
Old 02-03-2019, 10:21 PM
athomas's Avatar
Glad you got it !!
Old 08-01-2021, 02:20 PM
sailrj sailrj is offline
Default Double thanks
I've been looking for the rear lift installation instructions for over a month and just found these. Exactly what I need to finish the 3 point hitch installation on my Cub 104. The more I use this site, the more I appreciate everybody on it. Thanks again.
Tags
double thanks!
