Old 03-03-2019, 11:09 PM
redduece07's Avatar
redduece07 redduece07 is offline
I was afraid someone would say that!
1882 SGT
60" Haban deck
Old 03-04-2019, 10:13 AM
mickb72 mickb72 is offline
Originally Posted by redduece07 View Post
Thanks George. That is what I needed to hear. I m just having a hard time wrapping my mind around having 3 magnetos that are bad with 2 of them being new. I guess they don't make Chinese knock off parts like they used to! Anyone ever try the Oregon brand magnetos? I can get one of those for half the price of a Kohler.
My friend just went through this. Our NAPA sells both. He bought aftermarket first, dead, right from the start. Then oem good to go. Mike
Old 03-04-2019, 01:54 PM
cooperino's Avatar
Rather than guessing. I wonder if someone here knows the impedance of a new coil. Might be good to test them.
Old 03-09-2019, 03:05 PM
redduece07's Avatar
Update:
So, I bit the bullet and purchased a oem Kohler magneto. The good news is that I have spark and that in order to get spark on a Mag 18 all you need is a good magneto and flywheel magnet. But, might I suggest that if you do this test make sure there is no fuel in the carb. In my haste to check my new magneto, I created an OH S***! moment, and as my plug that I removed from the head had just enough time to spark once, the other fired inside the other cylinder and the engine started....on the bench. That will get you blood pumping if your not ready for it!
1882 SGT
60" Haban deck
Old 03-09-2019, 03:11 PM
redduece07's Avatar
Also, I put a meter to the new magneto vs. the old ones and found this:
Between plug wires
Old OEM magneto: 28k ohms
New OEM magneto: 32k ohms
#1 Chinese magneto: 15k ohms
#2 Chinese magneto: 15k ohms
All were open to ground.
1882 SGT
60" Haban deck
Old 03-10-2019, 07:23 AM
Not good. OEM, with respect to specifications, is always best.
