Use a piece of white foam that is wrapped around electronics for packing press the tin piece on it to make an outline then cut out.
thanks! mine only had half a tin piece is that normal? does the tin go over or under the foam piece?
Model 100 Dec 2020 - Running condition, has snow plow! Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one Model 100 Feb 2019 apart for total frame-off / sandblast etc resto Model 70 Sep 2020 needs total resto and an engine, or for parts Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts. two spare hydro rears "in for a penny, in for a pound!" |
The tin piece is suppose to loo like these.
Up to 534 and counting... I give up updating my profile! |
Ok I dont have that. When I get one does the foam go between that and the steering box and the swing plate rubs on that aluminum?
You got that right m man!
I cut some high density foam to thickness on my table saw then used the metal piece to cut the foam to size. Worked great.
also separate prob, I dont have the metal piece hoping not to have to get that new. may be better to find a used steering column...
nevermind, found a seal and retainer online for a halfway reasonable, and a wet brake pad as well...
"in for a penny, in for a pound.."
My friend told me about "Corn Head Grease" for the steering box. I looked that up and it sounds pretty amazing, a grease when not in use, but semi-liquid where it is needed when moving.
Anyone curious about corn head grease might find this post on another forum interesting...
http://forum.studebakerdriversclub.c...Tractor-Supply |
