Old 04-04-2019, 10:43 PM
sorner's Avatar
sorner sorner is offline
My problem is not fixed. It’s pretty tight but still “takes off”. What gives.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 04-05-2019, 10:24 AM
Check to be sure your trunnion is not worn, missing springs ect ect...
Old 04-05-2019, 10:48 AM
sorner's Avatar
The trunion is in good shape. This is the pump I swapped a ported pump into from a low hour 1862. I changed over the plate from the old pump to hook up for the 123 linkage.
The issue is the tractor when under a load pushes the lever up to max speed. Just driving around the yard does not do it since adjusting the tension but it does it when I'm making it work, last night I was running my cultivator to level out my garden.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 04-05-2019, 11:48 AM
ironman's Avatar
ironman ironman is offline
This would only be a guess from me, but may maybe you've got a lot of crap down there in that friction washer stuff that is not letting it hold, or maybe broken spring. Taking it apart to check, undoubtedly not fun, but????
Old 04-05-2019, 12:12 PM
sorner's Avatar
I was thinking the spring might be an issue, based on how much it compressed down (Post #6). I don't even want to think about replacing that. I parted out the other 123 and no longer have that piece, and it was a SOB to get apart just to get that out.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 04-05-2019, 01:19 PM
Looks like fun to me!
You may have to do one of those PO modes it see, adding some springs to the go go arm.
