Old 04-16-2019, 08:10 PM
wagonmaster wagonmaster is offline
Default Knobs
Golf balls have worked for me.
Old 04-17-2019, 01:15 PM
Marko141's Avatar
Marko141 Marko141 is offline
Some more photos.
You can see there’s a wire not attached to anything, haven’t traced it to it’s origin yet.
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 04-17-2019, 01:18 PM
Marko141's Avatar
And it’s not for the lights.
File Type: jpg EE1BFF88-19FA-4AD5-AB8C-91CCA58BD1AB.jpg (28.7 KB, 94 views)
Old 04-17-2019, 01:21 PM
Marko141's Avatar
Not sure what it’s for but I’m sure I’ll need it.
File Type: jpg E39573ED-B18C-41A6-BD17-814535680F24.jpg (22.5 KB, 94 views)
Old 04-17-2019, 06:21 PM
Originally Posted by Marko141 View Post
There is a little surface rust on the deck and that’s it.
Photo of the plow.
That plow will polish up like new after about 5 acres
Old 04-17-2019, 07:48 PM
twoton twoton is offline
Looks like the motor mounts have collapsed as the timing hole is below the top of the frame rail.
Could be the pto wire.
Old 04-17-2019, 11:58 PM
Marko141's Avatar
I’ll check the mounts thanks for the heads up, and yes it ended up being the pto wire. Everything works as it should now! I will be needing a rear lift setup so if anyone has one they want to get rid or know of a one that is decently priced I would be interested. I saw one for $125 but that’s only $25 less than what I bought the entire tractor for and I can not justify that purchase.
Old 05-21-2019, 12:17 PM
Marko141's Avatar
So this 1450 came with a deck and mule drive attached to it. After some looking, this is a 44c deck. After some reading I see that it is not very common to have this deck on this mower. I’m needing some blades and spindles, any references for part numbers for this deck, I would like to get everything in good working condition.
Old 05-21-2019, 01:55 PM
cooperino's Avatar
Heres the operators manual found here in tech section
https://www.onlycubcadets.net/pdf/44...p%20Manual.pdf
The parts breakdown can be found in cub cadet park lookup at top of page
Old 05-21-2019, 02:25 PM
Do you know if your deck has the water pump style spindle bearings or the automotive style bearings?
