Old 05-27-2019, 12:16 PM
dbuck dbuck is offline
Smile
Don, if you can get a 12v test light or a meter, you should have 12v or a light:
At battery positive terminal
then at the black wire at the key switch
The red/black wire at the key switch in the start position
After that it goes through the brake switch and the red wire coming out of it
To the pto switch still a red wire and exits the pto switch through another red wire
Then goes through the engine connector and becomes a blue wire that goes to the starter solenoid.
Sounds to me like the pto switch internal “off” connection that carries the start path through it is faulty but testing with light/meter will confirm.
However, if it already has the add on relay mod which it sounds like it does, we will have to know that as well because the blue wire that normally attaches to the start solenoid will then be going to only trigger the relay coil then the relay tips send pos to the starter solenoid via another added wire. Please report back
Yes if does have a Bosch relay # 032209150, 12V,20/30A.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 05-28-2019, 04:42 PM
Smile To the Dealer:
I am tired of messing with this thing, so it is off to the dealer.
Old 05-28-2019, 04:51 PM
I wish you luck,
many "Dealers" have no experience on our older equipment, thus, don't work on them, but are quick to sell you the newer junk.
Old 05-29-2019, 07:15 PM
Smile
I wish you luck,
How true that statement is. I am going to sell this 1864 after it is running and my 149 also. Then I am going to buy me a zero turn.
Old 05-29-2019, 07:57 PM
I have been known to buy a few 1864's that don't run.
Old 06-01-2019, 06:25 PM
I decided one more try. It now will run. The blue wire to the relay had power but the red wire going from the relay to the starter had none. Defective relay. As I could jump the blue wire to the red wire and key start it. What a trying time. Thank you everyone for your post. American Flag 1:
