Old 07-25-2019, 06:35 PM
Originally Posted by magoocher View Post
Thanks for all the feedback. I am going to keep it no matter what even I do decide on a new tractor.
Main thing I could use now is a service manual for the 1864. I found the owners manual but need more info. Need to replace the PTO belt to 54" deck but can't find procedure on how to properly adjust it?
Any help or links to download info would be great!
Should be a sticker on the front of your mule drive that tells you how to adjust the PTO belt.
I don't think there is an 1864 manual. Use 1862 for reference.
Old 07-26-2019, 08:26 AM
bugeye bugeye is offline
The PTO to deck belt is adjusted using the threaded rod on the front of the mule drive. The pulleys should be close to the same distance from the mule drive bracket holding the threaded rod and spring tension indicator (the bent metal thing on the front of the mule drive). The indicator has a small V notch and square lock notch slot. The tension is is adjusted with the rod such that the front mule bracket is between lock notch and V notch.
The belt tension adjustment is described in the deck owners manual. Perhaps a manual is available online or ebay.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
