Old 07-25-2019, 08:46 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default 149 Short?
SHORT FOUND. Downloaded the wiring diagram as suggested by Roland,(turns out I already had it in my Cub Work Book). All wires were hooked up correctly as I felt sure they were as it had ran well about a month and a half ago. Started disconnecting wires one at a time and touched neg cable to battery to see if it sparked. It just kept on sparking. Unhooked the pos. cable from starter. Still a spark. Disconnected pos. cable from battery to solenoid, still a spark. Knew then it had to be the cable from the pos. battery terminal. Followed cable from battery and discovered a stupid thing that I had done. I had put a bolt thru bottom hole in hydrolic clevis. Bolt was way too long. Pos. cable had dropped out of harness holder and gotten underneath the bolt. I guess I moved the hydrolic lift lever and the bolt dug into the cable, shorting it out. Took bolt out and am leaving it out. Thanks to all that responded and hopefully some will learn from my stupid mistake. The 149 is running again. Have a great day.
Bob
Old 07-25-2019, 10:23 PM
MBY852's Avatar
MBY852 MBY852 is offline
Glad you got her figured out there Bob! Crazy how some things happen.
