Old 08-06-2019, 04:03 PM
Take the breather OFF and do the compression test again. See if the Dipstick moves.
Old 08-06-2019, 04:33 PM
sounds like the CR is not working.
Old 08-06-2019, 05:27 PM
dale c. dale c. is offline
the dipstick shouldn't be loose in the tube
Old 08-06-2019, 05:45 PM
Yup, I agree
Old 08-06-2019, 06:24 PM
IHCubCadet147's Avatar
IHCubCadet147 IHCubCadet147 is online now
Is the o-ring on the dipstick in good condition?
Old 08-06-2019, 07:11 PM
Giddy Giddy is offline
The o ring is in good shape. How do you check compression release?
Cub cadets models. 123, 1250, 3 -1450, 1650, 782,982 ,1711
Old 08-06-2019, 07:14 PM
Why are you evading the simple test of removing the Breather assembly and doing another Compression Test..???
Old 08-06-2019, 07:20 PM
cooperino's Avatar
You have gotten a lot of great insight of things to look for.
My first question would be.. Did you overfill the crankcase with oil??
Old 08-06-2019, 07:45 PM
West Valley G West Valley G is online now
Might seem a little silly but are you sure it is the correct dipstick. I have
seen the wrong dipstick put back in an engine when rebuilds were done.
If its to long it will indeed move some as the crank nudges it.
Ken
Old 08-07-2019, 12:49 PM
I check the simple stuff nothing different. It won't turn over hardly with spark plug in it until it get on compression . I took cover off cam gear looked at A C R springs are all there
