Old 09-11-2019, 10:18 PM
IHCubCadet147's Avatar
As said by others if the deck is used, it is going to get blasted by debris.
If one has sandy soil or bare spots, nothing is going to hold up.
oh and mulching dry leaves will clean up the underside of a deck like sandblasting it. BTDT
Originally Posted by cooperino View Post
What he said! I usually paint the underside of my deck after my agrifab leaf sucker has sucked its last leaf of the fall.
We’ll see how long it lasts. If it needs, I can put another coat of paint on at the end of the season.
If its really rotted like you say, sand blasting will more than likely leave you with a sieve
I’m not going to sandblast it, just wire brush the heavy rust off.
Old 09-18-2019, 09:23 PM
After a rust converter and two coats of Rustoleum, it looks much better now. We’ll see how long it holds up.
File Type: jpg 15A8FF5D-715C-45F2-9D50-FF21994EE03B.jpg (20.6 KB, 59 views)
File Type: jpg 3A3905C8-0599-438F-A621-D699B9CBCD08.jpg (27.8 KB, 59 views)
Old 09-19-2019, 06:34 AM
cooperino's Avatar
Looks good
Is this mower deck on leaf duty in fall?
Old 09-19-2019, 10:36 AM
Looks like a really rough underside surface.
I would not expect that to shed grass clippings that are damp very well.
Good luck!
Old 09-19-2019, 10:15 PM
Looks good
Thanks. They only have 1 tree, so there won’t be a lot of leaves.
Good luck!
It can’t be any worse than before.
Old 09-21-2019, 07:43 PM
I tested it out today. The grass didn’t seem to stick too bad. We’ll see how it holds up over time.
File Type: jpg C5E622C6-80C3-44EC-90F0-40A28F897714.jpg (40.7 KB, 29 views)
