Greg Rozar AKA- CubDieselFan
Old 09-23-2019, 09:13 PM
Looks very nice, no cobble job there
Old 09-23-2019, 09:19 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
If you could add foot control you'd have the perfect Cub Cadet!
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1210 1250 1415 1420 1440 1450 1535 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3205 7265
Old 09-23-2019, 10:42 PM
farmall fred's Avatar
farmall fred farmall fred is offline
Thanks. I have been wanting to do this since I did my last custom build.
Since this will be a loader tractor I may look into doing this. It needs to be smooth for the wife to be able to use it.
Old 09-25-2019, 08:41 PM
Top notch work!
Old 09-25-2019, 10:49 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
Wow! Truly a work of art I like it
IH cub cadets 800x3,1000,1100,1200x2,1250DS,1450,1650DS, 71,122x2,123, 73x2,106,107,126x3,127,147x2,86x3,128,149, 169x2 ,Original, cadet 55, to name a few
CCC machines
1282,1050,2072,1535,1440
Old 09-28-2019, 10:23 AM
Thanks guys.
I removed the loader from my 1650 and started modifying the sub frame to work on the 2182 I had to do some trimming on the area where it bolts to the frame near the steering cylinder mount on the tractor and drill some different holes in the sub frame. I will also have to change the mounting points for the diagonal braces that go from the uprights to the front of the tractor frame. The power steering cylinder is in the way. I will probably just lengthen them to able be go to the holes in the front of the frame right under the grill. In the back since the super is longer I made up some angle iron brackets to use existing holes in the frame in front of the rear axle and also use the existing mounting holes in the loader frame. I have a set of axle braces on order and will use them tie all of this together. I do not have any pictures yet but will post some when I get farther along. So far it all looks good.
Old 10-04-2019, 09:44 AM
Default Loader install progress
Just about finished with the modifications to my kwik-way loader so I can install it on my new super. I had to do a bunch of grinding and rewelding to repair previous owner botched repairs. At one time in its life this loader must have been used ad a battering ram. I could not believe all of the cracks and bad welds. all of the mounting holes were all egged out like it was used with them loose. It must have had the damage done before it was mounted on the 1650 it was on because that tractor is in great shape and none of the holes in the frame where the loader attached are egged out. I hope to finish up today and paint the subframe and upright supports. I will paint the main frame of the loader later as I have some repairs I want to do to it.
Left side attaching point for subframe.I had to trim to fit shape of frame and drill new holes to use existing holes in the tractor frame.
Right side of subframe mount
Rear axle support braces installed and L bracket to mount rear of subframe. Again I used existing holes in the tractor frame. I plan on drilling a hole in the L bracket and through the axle support brace and bolt them together to add further strength and support.
I had to make new diagonal braces to go to the uprights because the power Steering cylinder was in the way of the existing mounts on the subframe. I made a bracket that bolts to the front of the frame. I need to cut the tubes to length and drill them so I can bolt to bracket. With some luck I should have the loader installed Saturday.
Old 02-07-2020, 05:08 PM
Thanks for this thread, I have the same situation pretty much. I have a 2182 with no motor or hood and a johnson 10 loader that is currently on a wheel horse.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 02-07-2020, 05:35 PM
RLause's Avatar
RLause RLause is offline
Tom, how is this project coming along? I was hoping to see some pictures before long.
Richard
Old 02-07-2020, 07:10 PM
gsomersjr's Avatar
If a Cyclops super had a steel nose and foot controls it would just about be the perfect garden tractor.
