Old 09-29-2019, 07:07 AM
cooperino's Avatar
Originally Posted by Gompers View Post
Well there technically are flywheel magnets that trigger the magneto, but they are the ones on the outside of the flywheel, not the inside.
I'd also check to make sure that the PO gapped the magneto properly.
Of course Sam knows this. Some people confuse the mag and stator and what they actually do. The permanent fixed out magnet on the flywheel rarely if ever go bad. More likely that they could be damaged by a improperly installed mag.
The magnets on inside of flywheel for stator charging did have problems in a number of different models with coming unglued. These magnets have nothing to do with spark.
As Sam said. I would be looking at the kill wire circuit. If its grounded, you wont get spark
Old 09-29-2019, 01:42 PM
Gompers Gompers is offline
Oh I know he does.
was replying for OP vs. Sam.
And yeah, basically all the KT/Mag engines had a problem with that. Don't know how widespread it was outside of those, but I'd assume kohler used the same stuff to glue them in on all of their engines.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
