Old 10-21-2019, 02:59 PM
Merchlewitz Merchlewitz is offline
Originally Posted by Marks1250 View Post
Here you go, check your local Lowe's if Item # 95535 Model # OEM-725-0267A is in stock
Thank you!
Old 10-21-2019, 10:14 PM
mortten mortten is offline
You want Item 8744. 95535 is an entire switch.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 10-22-2019, 01:21 AM
Looks like the battery is toast.. what's the best one to put in these?
Old 10-22-2019, 10:52 AM
It takes a standard lawn tractor battery. If you are going to use it in the winter find the highest CCA rating you can.
Doug
QA-36A
42" blade
Old 10-22-2019, 11:43 AM
Marks1250's Avatar
Marks1250 Marks1250 is offline
If you have a tractor supply close by.......
