Old 11-17-2019, 05:59 PM
Nice work Daniel, is the motor new?
Up to 534 and counting...
Old 11-17-2019, 07:32 PM
Thanks
I did not buy the motor new- it came with the package with the rockshaft etc....but I think a PO put a new motor on it. I was pleased when I saw that it spun and changed directions when I bench tested it. I made the mistake of opening the motor up ( so I know the brushes are good) but talk about a real PITA reassembling it.
Old 12-31-2019, 09:46 PM
wagonmaster wagonmaster is offline
Default Thanks for the clue
Got some parts and technical help from Charlie P (cub cadet specialties) that combined with the manual I got it put back together yesterday. New bearings, pinion bushing, seal, and set screw- lubed everything up, had to make my own wiring harness as it was gone...but it works good. Needed some tweaking but I'm very happy with the way it works. Initially I had the slip clutch too loose and the transverse tube would spin almost constantly but that was an easy adjustment. My right arm is already happy for eliminating that manual lift. So will my right knee as it won't constantly get whacked.
Next spring when it warms up I may throw some paint on it.
https://www.youtube.com/watch?v=Q6Huqe0_s0I
Thanks Dan, now I know what was wrong with my E-lift. My clutch was to tight so when it hit the end of travel on extension it would push the pinion bushing out the bottom of the housing.
