Old 12-11-2019, 04:23 PM
KCabuzzi KCabuzzi is offline
Thank you Mr. Bob ! I will be sure to check that and look into one of those custom rods. Thanks again sir ! - Kevin
Old 01-06-2020, 01:59 PM
Stoltz80's Avatar
Stoltz80 Stoltz80 is offline
i made my own rod...ended up making 2 the one that worked best has the 90* bends 180* from each other at 28.5" . i found with both bends in the same direction the rod flexed quite a bit actually. with them opposite each other the rod is slightly touching the mounting bracket to the blower keeping it from flexing. im also running a back blade. and Jeff using your sleeve hitch adapter its been working great thanks alot man!! i keep the thrower 2 inches ish off the ground due to gravel drive then have the back blader just kissing the surface to clean what the thrower leaves....well this is in theroy we have yet to have snow of any accumulation. go figure im finally ready to keep my 1?4 mile long drive clean and its been in the 50s in north east Ohio all winter it seems.
Old 01-06-2020, 02:08 PM
Stoltz80's Avatar
Feel like I have a real hard time posting pictures to this site...almost always too big ..how do I fix that?
Old 01-06-2020, 09:31 PM
I found by saving them to my computer hard drive makes them an acceptable size.
Old 01-08-2020, 01:38 PM
Stoltz80's Avatar
Default Test pic
Thanks Jeff I think it worked
Old 01-22-2020, 09:08 AM
PennDude PennDude is offline
What back blade is that? Great looking setup. I inherited a 149 that’s now at my local small engine mechanic for some extensive engine work. Smoked so bad I had to shower after every use! I’d love to set it up like yours for clearing snow.
Old 01-23-2020, 11:57 AM
Stoltz80's Avatar
I purchased a cat 1 back blade off marketplace or let go, cant remember which. then I cut the 3 point bracket off and fabbed up this set-up using hitch receiver tubing. it works great.
