Old 12-10-2019, 07:50 AM
MrRazz MrRazz is offline
I cant even descibe how valuable this site is. Thank you!
Quietline 1250
Old 12-10-2019, 09:13 PM
Merk Merk is offline
Originally Posted by MrRazz View Post
I was surprised to see the lift rod that doesn't work with my blower works correctly for my plow. And something i did notice is when i put the plow all the way down, i can actually lift my plow up a few inches. Is it supposed to have some floating ability or is it supposed to be locked into that position? My lift cylinder isn't moving, it seems to be all in the mounting and connection mechanisms that i get the movement.
Does your Cub Cadet have hydraulic lift?
I wouldn't use the lock out pin when using a snow thrower or blade. Good way to break something.
Here is my IH Cub Cadet 149 that has hydraulic lift with the float lock out in place:
Project Uncle Dick
Cub Cadet 70
Old 12-10-2019, 09:15 PM
My IH Cub Cadet 149 that has hydraulic lift not using float lock pin:
Project Uncle Dick
Cub Cadet 70
Old 12-10-2019, 09:39 PM
It has hydraulic
Quietline 1250
Old 12-13-2019, 02:26 PM
DownNdirt's Avatar
DownNdirt DownNdirt is offline
I have the same issue with not being able to lift blower with my 1250 hyd. lift, 28" rod too. In going to put a chain lift on it, but I am thinking about hooking it up to my 1450 to see if it's any different.
'78 1250, '79 1450, '77 1000
Trapped and released: 124, 1000, 72, 1211
(JD) '70 140 H3 patio yellow, '74 140 H3, '87 332 diesel
Attachments: too much to list
Old 11-14-2020, 11:31 AM
Ambush Ambush is offline
Found this thread while cruising around and I have a question.
Is the lift arm float in Merk's pics standard on 149's?
My newly acquired 1973 149 does not have that lock/float block, but at some point the arm broke and was (poorly) repaired, so it could be missing.
I have to pull it and do a proper repair, but before I cut it back and weld a new end on, it would be great to have the actual measurement from the center of the rocker shaft to the center of the piston eye.
Being a first time owner of a "big" Little Tractor, just reading hundreds of threads here has been a real education. Sometimes you have to move a lot of dirt to find a little gold, but it's there! Thanks all!!
Old 11-14-2020, 12:10 PM
The lift arm float is the way your tractor can from the factory. Lockout pin is an option.
Project Uncle Dick
Cub Cadet 70
Old 11-14-2020, 12:49 PM
Thanks for the quick reply and info, Merk!
For my purposes, since I'll never have a mower deck anyway, I'm going to eliminate the float on that connection. I'll fab a float for the front lift arm and provide float for the rear lift.
I am, of course, finding some well intentioned but poorly executed "repairs" as I go along. The frame for the plow was remade and now I have to redo that.
Next is remove all the shafts and linkages from the lift system to take all the slack out of there.
Old 11-15-2020, 04:29 PM
gardenpest's Avatar
gardenpest gardenpest is offline
Did you make sure the mounting
bar used for mounting is swung up and locked out of the way ?
149..... qa-42 snow thrower..#1 tiller w/extentions, 109 w/deck, 129 w/blade 1450 w/deck
Case 444 gt.....H270 toro wheelhorse....Massey 135 diesel.....52 GMC
