Old 12-01-2019, 11:03 PM
Brunsace's Avatar
Brunsace Brunsace is offline
Originally Posted by Aircomet View Post
This is what I am trying to explain to hold it in place.
Ok. Took a minute but I see now. Thanks! I guess I'll need a measurement for the slot location too if it's not the same as it is on the curved links.
Old 12-02-2019, 08:56 AM
If you are going to make your own upper links and offset them, make sure
you make them a little longer than needed till you get your holes where you want them, as you can always cut them off.
The thrower's front edge works best if it is at a right angle with the ground while supported.
Also check chute clearance @ front of grill,both full left/right and allow extra as
clearance does decrease due to hole clearances/slop and quick attach slop.
