I think If I was planning on using it quite a bit and not making it original show type piece I would make new bushings on the lathe with oil embedded bronze.
My thinking is the wooden bushing is a wear item. To me, replacing these with something like bronze is a no-go. UMHW would be my choice for a modern day material.
Alan Basket Cases: 129, 1450 sold, 1650 125: 48" Mower Deck, Windbreaker Cab 127: 3 turn steering gear, Spring Assist, Sleeve Hitch, 48" Mower Deck, Dozer Blade 147: 3 turn steering gear, Spring Assist, QA36a w/Xtreme Motorworks Wings |
I would not over think this, you don't have the precision to use metal/bronze
H.Density nylon etc. it was built with wood in mind and it lasted all these years. Why change a good proven thing. |
Exactly what you said George, you are spot on.
Ol'george is the most correct. KISS.
A tree limb, a saw, brace an bit, and a draw knife. Call it done
When I was a teenager I'd replace everything when working on a car now I want to keep it simple as said,just what's needed. A friend is a looger I'll get some maple from him.
Thanks for the address.
If you can get your hands on some lignum vitae wood, that would be real good!
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
That wood is also quite expensive too.
