Old 05-28-2020, 12:01 PM
Banman Banman is offline
A walbro will only have one adjustment screw
A Carter will have 2, an idle screw and a high speed screw.
Post a picture of it.
What's wrong with it anyway?
Came off the 129 I bought the other day https://www.onlycubcadets.net/forum/...ad.php?t=57087
So hopefully nothing wrong with it that a through cleaning won't fix. It looked clean inside the bowl and throat but it's obviously been sitting...
The engine it was on is a 321A if that matters...
The p/n stamped on the carb is A-237771
Is that an oem cadet or kohler p/n?
putting that part # to amazon gave me this which does look the same minus having a p/n stamped on the body.
https://www.amazon.com/CARBURETOR-F-.../dp/B01M62O80S
Old 05-30-2020, 11:05 AM
Cleaned it up yesterday enough (to take apart) to properly clean and rebuild it later...
And with more cleaning, more p/n were revealed -- C-275369 cast into the body
From this thread https://www.onlycubcadets.net/forum/...ead.php?t=5107 I've determined that it is indeed an oem Carter carb for a K321A
It's interesting to compare the differences between this one and my chinese copy. The brass bits are all a bit more refined on the oem, and the fuel bowl and float are thicker, so more durable...
Of course, it would take a machinist's kit to measure how closely the jets and passageways actually match between the clone and the oem...
