Old 05-28-2020, 06:16 PM
REO Clinton REO Clinton is offline
Default what is it
A 1720 with a 54'' deck and a magnum 17 that may well be frozen. the air cleaner is off of it. one front tire and one rear wheel are sort of off the rim.
Near Clarksville Md and free to the person who helps me load a finish mower I bought.
I get to keep the key unless it's a deal breaker.
It's a woods rn 59
Thanks for the input and the kind replies.
Old 05-28-2020, 06:35 PM
Banman Banman is offline
It's a woods rn 59
Parts tractor I just picked up with one tire looking like it was rotted off the rim and the other 3 all cracked through to the inside -- they all aired up even the one off the rim after I seated it. 24hrs later they're still holding air!
If you have a portable compressor take it -- getting air in the tires makes loading 'em a lot easier!
Old 05-29-2020, 11:18 AM
Default What might it be?
thanks for the inflation idea.
According to tractor data it's a 46 inch deck. My error.
The metal and hood seem good and I would hate to see it go to the scrappers
On the side of the engine closest to the driver there appear to be motor mounts.
Are the engine cases the same for horizontal and vertical shaft engines, and having a different "oil Pan" with a different oil pickup and dip stick location, in addition to a different oil pickup?
Old 05-29-2020, 01:48 PM
Oh God,
I explained this multiple times and converted one from a vertical to horizontal out of a 1720 about 10 years ago.
----Just because most said it couldn't be done.
The block raw casting is the same, but is machined for either horizontal or vertical applications at the factory.
The crank had to be shortened, machined and a bushing made and key-way milled.
The crankcase cover had to be obtained from a horizontal engine as well as a manifold and gov linkage from said.
The dipstick boss had to be drilled in the block, oiling drain holes in the cylinders plugged and passages drilled so the oil pump could suck out of the sump as well as a expansion plug installed, after passage way was drilled.
Suction screen installed on the suction tube, oil drain plug installed in the sump.
I'm sure there are things I've forgotten. The engine is still in use with prolly 1500+ hours on it.
I did do a .010 overbore & Kohler NOS pistons/rings about 300 hours ago.
The average Joe plumber without a lathe or mill will not accomplish it. The cost to have it done, is plum stupid.
Your engine is worth keeping for parts as is the deck spindles, scrap the rest.
If you want to keep the anti scalping wheels off the deck they can be made to fit the early 50 A&C decks that didn't have them.
Now my typing finger hurts and it is lunch time.
Old 06-01-2020, 11:27 PM
Tomorrow we go on a fools errand to retrieve it. Only because a kind soul with a 4wd tractor with loader will help out.
The odds of pulling the heads and tappy tappy on the pistons to get moving is is?
I guess if I pull the heads and water gushes out, oh well.
Can an engine with closed valves be hydraulically unlocked? An adapter into the plug hole, a grease gun, and pump away?
Old 06-01-2020, 11:58 PM
You don't wanna force it...
After you get it home -- pour a 50/50 mix of atf and acetone down the spark plug holes -- enough to cover the piston tops, loosely replace the spark plug, and let it sit for a day or three... then gently just working the flywheel back and forth.
A new tractor seat costs $90 and this one looks decent...
Old 06-02-2020, 08:31 AM
If it is a 1720, it is a belt driven transaxle no relief valves per say.
the engine is prolly semi free as not an easy way for rain water to run in,
it being a vertical application.
Thinking it might have a small puck type brake caliper that might be stuck
preventing rolling.
You can look it up in cub parts look up in the link at the top of the page.
Been too many years for me to remember positively.
