Old 06-06-2020, 11:55 PM
ajplacke ajplacke is offline
if you are getting air pressure in the reservoir you have to be sucking it in somewhere.
the suction line is under the oil level so it shouldn't happen.
is the nut tight on the suction tube on the bottom of the hydro ( it is by the side of the filter and goes into the front of the rear housing at the bottom).
i'll look into that in the morning and reply asap
Old 06-08-2020, 12:00 AM
took the suction tube off put a new o-ring on. havent fired it up yet. but i'll re pressurize it and start her up some time this week
Old 06-08-2020, 06:45 AM
Please elaborate, I don't remember an "O" ring on the suction tube.
The top has a tubing nut on the flair where it screws to the hydro,the other end where it goes into the diffy case/reservoir, has a brass compression fitting.
if they don't leak they are usually ok.
Reviewing:
Did this tractor work properly before you decided to change fluid/ filter?
Old 06-10-2020, 01:00 AM
Reviewing:
where the suction tube screws onto the hydro pump there was an old dry rotted o-ring, no other compression fitting or tubing nut. so i replaced that. the 1250 is a project i picked up in march. it was rough, sat for lord knows how many years. previous owner had it given to him by an old collector who passed away. it looked like someone scavenged parts off it. it was missing ignition, pto switch, coil, starter. i've gotten the engine back up running. i'm just stuck right now on this tranny.
Old 06-10-2020, 07:51 AM
ok if you look at the Cub cadet parts look up at the top of our page banner
you will see a fitting that screws into the hydro, yes it has an "o" ring but I have never ever removed that fitting as no need to, but no problem.
I just loosen the tubing nut on the tube that screws onto it,and remove the
suction tube.
Thank you for the clarification, we now know no one has any idea of the hydro's condition, and we should assume nothing.
As far as we know a rag/obstruction could be in the suction tube.
Or someone could have swapped charge pumps and left the "O" ring seals off or installed it 180 off rotation and it won't pump.
Or worse it was "done blowed up" as the good ol'boys say in NASCAR
So where does that leave you?
swap in a known good hydro from a reputable seller or keep trying to find the hidden cheese like a hungry mouse.
That is what I would do because I am "curious George"
Sorry I can't help more, maybe others will have a idea.
does the charge pump look as it has been removed/loose bolts?
Old 06-15-2020, 12:21 AM
thanks george! i'll re check the suction tube for obstructions. the gears all move freely, i checked that when i changed the fluid. if i take the hydraulic pump off is there anything to look for?
Old 06-15-2020, 06:31 AM
The charge pump MUST be installed the way it was originally installed and not turned CCW from the original position.
Question: Did this unit work properly BEFORE you changed filter and fluid?
Old 06-16-2020, 12:04 AM
nothing worked when i took ownership this march. probably hasnt run in last 15 yrs.
