Old 06-21-2020, 05:52 PM
bassnailer bassnailer is offline
Quick update. Since my last post, I noticed oil dripping from the supply line near the filter. I have drained the fluid, replaced the o-ring, and filled it back up with the synthetic blend Rotella. I also took the posted advice and marked the axles and wheel with paint to index the location of the splines relative to the wheels. I test drove the tractor and it is now pulling small grades, which is an improvement. I drove it around the yard for about a half hour pushing it as hard as I could up grades to allow it to repeat the problem (hydraulic squealing and shuddering while not being able to go up the grade). After doing this, I checked the paint marks and they were indexed exactly as they were when I began (see photo below of mark after test drive).
Because replacing the o-ring on the supply line significantly improved the hydraulic power, I am thinking that there may be more seals in the hydraulic pump which are allowing pressure to blow past. Does anyone perform a rebuild service for these hydro pumps? I found a used one from a board sponsor here for $500, but hate to buy a used one which will develop the same issues in a few years and would rather put the money towards having mine rebuilt if such a service is available.
Old 06-22-2020, 10:24 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I would pull that cooler as recommended earlier if I were you. You might be surprised and would not need to spend that five bills....
Plow blade
#2 Cart
QA36 snowthower
Old 06-23-2020, 05:39 AM
I wonder if you have a cracked tube?
You can download the free manual here for doing some pressure tests.
https://www.mymowerparts.com/pdf/Cub...epair-Manuals/
Good luck and report back.
Old 06-23-2020, 08:49 AM
ejl6658 ejl6658 is offline
Have you tried replacing the bushings on your pedal linkages and tried adjusting them to see if it makes a difference?
Old 06-23-2020, 11:05 AM
Yes. I have replaced all the bushings and adjusted the travel pedals. The tractor moves great on level ground, forward and backward. It's just when I encounter a grade.
Old 06-23-2020, 11:11 AM
The problem existed before I added the cooler, and the cooler was an attempt to correct the problem. The problem doesn't exist when the tractor is cool and gets worse as I mow. Because the fluid was hot and frothy when the problem occurred, I was thinking the hydraulic fluid may be getting too hot. That's not the problem though, as I can lay my hand on the oil cooler when the problem is occurring and it only feels warm, not hot. Once I get it all sorted out, I will most likely ditch the cooler as it was more of a diagnostic tool than anything else.
Old 06-23-2020, 12:49 PM
Billy-O's Avatar
That's your call to make. You might have made matters worse trying to rectify the problem by adding the cooler. Now that you replace a seal, you reported the tractor is doing better. Is pulling the cooler and return the hydraulic lines to the original set up that difficult?
Plow blade
#2 Cart
QA36 snowthower
Old 06-23-2020, 06:21 PM
Fair point, it won't hurt anything to go ahead and remove it now. That way I can eliminate both overheating (because the cooler did not fix it) and the cooler itself as a potential source of air getting in the system.
Old 06-23-2020, 08:28 PM
Your transmission is a BDU-21L-500. Attached is the link for the BDU service and repair manual.
https://www.hydro-gear.com/service-and-repair-manuals/
There is also a pressure testing procedure in the 3000 series service manual.
Old 06-24-2020, 12:17 PM
Thank you, this is a great resource! I'll be testing the pressure this evening when I get home. I appreciate it.
Tags
3225, hydrostatic transmission
